Fuel vapour box thingy on A9X's
16 replies to this topic
#1 Shiney005
  • 9,578 posts
  • Car:Toyota Mirai
Posted 30 September 2024 - 08:38 AM
The first question I have is what does it do? Has anyone got a picture of one in a hatchback? And did all Toranas get them at some point including UC?
Attached File  1977-holden-lx-torana-a9x-sedan (17).jpg   271.61K   5 downloads
Attached File  Fuel box 2.jpg   51.88K   4 downloads
#2 yel327
  • 13,631 posts
Posted 30 September 2024 - 12:18 PM
Isn't that just the standard fuel tank vapour separator (fitted once canisters were fitted from 1/75)? Just raised higher to account for fitment of larger/higher fuel tanks in race cars?
#3 Shiney005
  • 9,578 posts
  • Car:Toyota Mirai
Posted 30 September 2024 - 12:21 PM
So only A9X's then?
#4 S pack
  • 15,720 posts
Posted 30 September 2024 - 12:54 PM
So only A9X's then?
AFAIK only A9X had the fuel vapour separator raised up above floor pan height inside a box.
All other LH & LX models were mounted under the floor pan.
Edited by S pack, 30 September 2024 - 12:54 PM.
#5 yel327
  • 13,631 posts
Posted 30 September 2024 - 03:58 PM
Co-incidentally I read about this somewhere in GMH literature in the last week. Looking for something else and moved on. Now you've raised it I'll go looking where I saw it. Edit - found and attached the front page.
And whilst looking for it found something else out in the LX POA docs:
N66, the 13x6 steel "sports" wheels. Was replaced at some stage with N67, the 13x6 alloy jellybeans. It says that N67 was to be introduced as soon as possible after the introduction of lightweight calipers. There must have been an issue with LH style cast iron calipers and fouling on alloy 13" wheels. My 2/76 SL hatchback had N67 on it.
Attached File  A9X copy.jpg   97.29K   8 downloads
#6 RallyRed
  • 8,144 posts
Posted 30 September 2024 - 06:25 PM
Rear discs larger than front...
#7 yel327
  • 13,631 posts
Posted 30 September 2024 - 06:52 PM
They just had what a Holden (and Statesman) had.
#8 Shiney005
  • 9,578 posts
  • Car:Toyota Mirai
Posted 01 October 2024 - 11:10 AM
Aren't N66 the GTS wheels?
#9 yel327
  • 13,631 posts
Posted 01 October 2024 - 11:17 AM
On a Holden they are the rally/sports wheels that were fitted to GTS (not called GTS wheels though), and N67 are the alloy 14" replacement that started on Sandman and GTS mid 1978 (also fitted to HZ SL/E mid 1979). This is Torana though, N66 simply means the sports wheel which is the 13x6, and N67 is the 13" alloy jelly-bean style.
#10 Shiney005
  • 9,578 posts
  • Car:Toyota Mirai
Posted 01 October 2024 - 11:24 AM
So these then?
Attached File  NOS Torana rims 1.jpg   69.78K   10 downloads
Attached File  NOS Torana rims 2.jpg   65.52K   8 downloads
Attached File  NOS Torana rims 3.jpg   79.18K   7 downloads
#11 yel327
  • 13,631 posts
Posted 01 October 2024 - 12:21 PM
So these then?
That's them. They may have been spare part wheels, like you could still buy HT-HG rims into the 80's as new rims. I had a few of them in the shed but sold one, gave some away and threw the others away, were hard to get rid of as back then everyone was still putting 14" wheels on every Torana.
#12 Shiney005
  • 9,578 posts
  • Car:Toyota Mirai
Posted 03 October 2024 - 02:08 PM
And then there are 4.5 inch ones. Were they an option an anything or standard on a certain model?
Attached File  sta. 4.5 inch torana rim 2.jpg   117.46K   3 downloads
Attached File  sta. 4.5 inch torana rim.jpg   164.91K   3 downloads
#13 yel327
  • 13,631 posts
Posted 03 October 2024 - 09:00 PM
Will check, might just be for LJ. Or TA maybe?
#14 S pack
  • 15,720 posts
Posted 03 October 2024 - 09:53 PM
13" x 4.5" were std fitment on 6cyl LC and LJ Torana S & SL.
Edited by S pack, 03 October 2024 - 09:54 PM.
#15 Dr Terry
Dr Terry
  • 3,324 posts
Posted 04 October 2024 - 08:13 AM
And LH & early LX.
Dr Terry
#16 Dr Terry
Dr Terry
  • 3,324 posts
Posted 04 October 2024 - 08:20 AM
Those wheels above (9929130) are listed a PO N66 "sports option" for LH/LX.
Dr Terry
#17 yel327
  • 13,631 posts
Posted 04 October 2024 - 10:15 AM
Dr Terry
Terry, that is where the wheels topic in this thread originally came from, post 9. I found where N67 replaced N66 and it basically says that they couldn't replace N66 until the lightweight calipers were fully in use. N67 became the sports wheel at some stage early in LX, just not sure exactly when as the POA doc page where it his has that revision over-written. My 2/76 LX hatchback had N67 wheels on it.
