Help priming ls3 crate engine and dipstick placement in moroso sump
3 replies to this topic
#1 horsepowerhowie
horsepowerhowie
  • 90 posts
  • Name:Howie
Posted 19 December 2024 - 08:28 AM
I’m about kick over my LS3 Hatch and wondering if there’s any engine priming procedures or special lubricants I need?
also I’m running a moroso sump with the original ls dipstick and unsure of the placement?
Any help would be great thanks.
#2 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 19 December 2024 - 08:04 PM
I used a standard dip stick but shortened the tube so I had to shorten the stick, did it be measuring with the sump off and comparing to the original and then made my marks on the stick by adding minimum oil and then full oil.
If you are using the original dip stick and the original tube in the same location it should be ok as it already suits the engine, sump shouldn't matter as long as it doesn't hit the tray with the Moroso being a rear hump.
#3 rexy
rexy
  • 3,737 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 22 December 2024 - 11:07 PM
Fill with oil and crank with ignition disconnected until you get oil pressure.
Then reconnect ignition, crank it and spank it!
#4 LJ RB30
LJ RB30
  • 1,035 posts
  • Name:Trevor
Posted 22 December 2024 - 11:21 PM
I pressure bleed any fresh engine these days. Or any you care about.
