308 thermo fan sensors
4 replies to this topic
#1 redtorana#3
redtorana#3
  • 107 posts
  • Car:1977 LX
Posted 21 December 2024 - 12:24 AM
Guys can you please let me know what you are using and where you are putting the sensors?
When I got the car my fan is controlled by a thermometer type tube that was placed in the top radiator hose. Not what I want.
Cheers. (I'll keep searching)
#2 76lxhatch
  • 7,207 posts
Posted 21 December 2024 - 05:53 AM
Before going EFI I used a Tridon switch mounted in the manifold (next to the gauge sender). These are relatively neat and offer built-in hysteresis (switches off 5 degrees cooler than on).
https://tridon.com.a...mo-fan-switches
TFS111 looks like a good option, that may have been the one I was using. Make sure it's a little above the coolant themostat temp or the fans will never switch off.
#3 Cook
Cook
  • 1,531 posts
Posted 21 December 2024 - 09:22 AM
Hi Brad. I have a Davies, Craig unit Into a port in the inlet manifold. The control panel is mounted under the glove box for access should I need to adjust the temp settings. Cheers Ron
#4 redtorana#3
redtorana#3
  • 107 posts
  • Car:1977 LX
Posted 21 December 2024 - 12:55 PM
Thanks gents, both look like good options. I do like the TFS111. Cheers
#5 yel327
  • 13,638 posts
Posted 22 December 2024 - 09:36 AM
I think WB had a switch in the top of the "top" tank just below the filler. just a threaded hole. I have seen them in HQ-HZ radiators too. The switches are cheap too. You don't have to switch a `2V wire with them either, you can just switch the 0V lead of the control relay, makes it neater.
