Temp light and guage
2 replies to this topic
#1 Rana101
Rana101
  • 48 posts
  • Name:Derek
  • Car:Lh
Posted 24 December 2024 - 06:24 AM
Good morning all
  finally after 8 years Iโ€™ve got the LH 192 on the road .
Have original temp light hooked up but want to run gauge also , question is can I tee off light sensor port in head or is there another spot that will work
thanks ๐Ÿ˜Š
#2 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 24 December 2024 - 08:04 AM
Lower thermostat housing is probably the best spot. Then you can leave the idiot light sender in the head. You need a dedicated sender for a gauge, and any temperature sender needs to be in the coolant flow, unlike pressure.
#3 Dr Terry
Dr Terry
  • 3,325 posts
Posted 26 December 2024 - 09:14 AM
You can't run a temp sender off a T-piece, the water must pass near the sender. With a T-piece the temp sender is too isolated & will read too low.
You can T-piece an oil pressure sender, but not a temp sender.
Dr Terry
