Gearbox boot LC
LC gearbox boot Aussie 4 speed
14 replies to this topic
#1 dacastle
dacastle
  • 107 posts
  • Car:LC gtr
Posted 13 January 2025 - 03:35 PM
What sort of gearbox boot are people using for aussie 4 speed into LC
Do rares have a replacement that fits the cutout profile I have?
II have looked on website but - maybe domestic blindness- I dont know
On a non related topic I am relocating my battery to the boot
Is it a matter of drilling holes thru firewall with suitable grommet and running cables thru the interior of the car?
This is definitely a slow process
#2 claysummers
claysummers
  • 3,635 posts
  • Name:Clay
Posted 13 January 2025 - 04:09 PM
I used a firewall pass through fitting with swaged or soldered cable lugs bolting up either side. Actually I made a copper bus bar and bolted one end to an isolator switch, with a short cable to the starter. Alternative is to run along the sill panel with d clamps, then a pass through into the boot. I would not recommend an ordinary grommet for fear of it rubbing through and shorting the cable.
#3 Indy Orange
Indy Orange
  • 2,944 posts
  • Name:Paul
Posted 13 January 2025 - 05:31 PM
Rehashing an old thread ,but for those that are looking for a boot option for LCGTR ,Matthew hit the nail on the head .The Nissan 720 gearshift boot will do the job ,nice tight fit inside the housing ,tried it under my console with no problems.
Attached ImagesHope this helps!
Edited by Indy Orange, 13 January 2025 - 05:34 PM.
#4 S pack
  • 15,723 posts
Posted 13 January 2025 - 07:40 PM
Attached File  Screenshot 2025-01-13 194005.jpg   69.84K   6 downloads
#5 dacastle
dacastle
  • 107 posts
  • Car:LC gtr
Posted 15 January 2025 - 06:52 AM
Thanks Clay
Thanks Dave
#6 S pack
  • 15,723 posts
Posted 15 January 2025 - 07:04 AM
Thanks Clay
Thanks Dave
There is also a square-ish metal retainer plate that goes over the flange of the boot to hold it to the transmission tunnel.
I can't remember off hand if Rares also do those.
Edited by S pack, 15 January 2025 - 07:05 AM.
#7 Indy Orange
Indy Orange
  • 2,944 posts
  • Name:Paul
Posted 15 January 2025 - 08:37 AM
No worries.
#8 dacastle
dacastle
  • 107 posts
  • Car:LC gtr
Posted 16 January 2025 - 07:32 AM
cheers Paul - I think this is the way I will go - the retainer bracket I have is as you have pictured
#9 S pack
  • 15,723 posts
Posted 16 January 2025 - 04:58 PM
Paul's retainer suits with the OPEL 4spd. It may not suit with a GMH 4spd shifter.
When the GMH 4spd was introduced into LC production in July 1971 the shifter rubber boot & retainer changed to the square boot and the floor console and vinyl boot also changed and all carried through to LJ.
Edited by S pack, 16 January 2025 - 04:59 PM.
#10 Indy Orange
Indy Orange
  • 2,944 posts
  • Name:Paul
Posted 16 January 2025 - 08:16 PM
AM
Hi 1971LCGTR.
To change from an Opel 4-speed to an Aussie 4-speed, you will need
Gearbox with linkages, bellhousing etc.
Clutch pate
Tailshaft & yoke
Crossmember
Speedo cable
The console is different but you can just move the original one, slightly.
By the way, it's only a small point, but an Opel is also an M20, so it's best to refer to the newer gearbox as an 'Aussie 4-speed'.
Dr Terry.
#11 Indy Orange
Indy Orange
  • 2,944 posts
  • Name:Paul
Posted 16 January 2025 - 08:23 PM
So you could just move the retainer and rubber boot over.
Does that Rares one even sit under the console?
#12 S pack
  • 15,723 posts
Posted 16 January 2025 - 09:57 PM
Not really, the retainer is shaped to suit the transmission tunnel.
The rares g/shift boot is a faithful reproduction of the OEM part and yes they do just fit under the console.
There are LCs around that have had the OPEL 4spd replaced with the GMH 4spd but still using the OPEL type console, so it seems to work however I wonder if there are any issues with movement of the shifter being inhibited that need to be sorted.
#13 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 17 January 2025 - 08:57 AM
i'm using the nissan boot in mine
aussie 4s speed and opal consel
it is tight for 1st and revers
tried to sorce a better one but to no avail
#14 dacastle
dacastle
  • 107 posts
  • Car:LC gtr
Posted 19 January 2025 - 04:22 PM
Thanks Paul - all the running gear is inplace already but I was looking for the best fit gearbox boot as I am slowly (very) starting on putting the inside of the car together. Unfortunately, I pulled the car apart 30 years plus ago but the help on this forum has been a life saver.
Hi 1971LCGTR.
Clutch pate
Tailshaft & yoke
Crossmember
Speedo cable
Dr Terry.
#15 dacastle
dacastle
  • 107 posts
  • Car:LC gtr
Posted 19 January 2025 - 04:25 PM
Thanks Albert I will get a Nissan gearbox boot I think
Also tagged with one or more of these keywords: LC gearbox boot, Aussie 4 speed
