Leaking Holley Carb.
20 replies to this topic
#1 hawk
hawk
  • 2,179 posts
  • Name:steve
  • Car:UC Torana
Posted 13 February 2025 - 07:46 PM
Hey Guys,
Just want some advice on my Holley.
It's a 600 vac secondary, that appears to leak only when left to sit.
While running I can't find a leak and leaving the electric pump running I can't see it either but if I leave the car for a while I find old fuel pooled and going bad/ sticky on the manifold. It's on both sides.
Any ideas?
I believe the pump is running 3 to 5 psi from memory. No pressure regulator in line or return line, would residual pressure in the line cause this?
#2 claysummers
claysummers
  • 3,618 posts
  • Name:Clay
Posted 13 February 2025 - 08:07 PM
Has to be coming from one of the float chambers. I would start by putting new washers on all the screws, fibre or nylon. If that doesn’t fix it it is easy to take off the chambers and metering blocks, and replace the gaskets. You shouldn’t need to unbolt the carb to do this.
#3 hawk
hawk
  • 2,179 posts
  • Name:steve
  • Car:UC Torana
Posted 13 February 2025 - 09:03 PM
Thanks, I guess I'll try to buy a kit for it on Saturday. I want to get it sorted before it goes in for its exhaust next Friday.
#4 Bruiser
Bruiser
  • 856 posts
  • Name:Bruce
Posted 14 February 2025 - 02:21 PM
Any excess pressure sneaking past the needle and seat would be pushing fuel straight up and out of the bowl vent tube
If this isn’t happening it means the needle and seat are doing their job ok.
I agree with Clay, probably just weepy gaskets.
Can get weeps coming from the accelerator pump too.
Might be easy to see when the carb is off and upside down
#5 hawk
hawk
  • 2,179 posts
  • Name:steve
  • Car:UC Torana
Posted 14 February 2025 - 08:50 PM
definitely fuel getting past the needle and seat with the electric pump on
#6 hawk
hawk
  • 2,179 posts
  • Name:steve
  • Car:UC Torana
Posted 15 February 2025 - 06:02 AM
I was watching it with the pump on amd saw it pushing fuel into the bowls. so I guess i need a inline pressure regulator?
#7 Rockoz
Rockoz
  • 4,027 posts
  • Name:Rob
Posted 15 February 2025 - 09:15 AM
Ran Holleys on cars for years without problem with no pressure regulator.
Its probably not a bad idea to have one, but there would be hundreds of thousands of them operating successfully without one.
Change the needle and seat first.
You can do a full gasket replacement/rebuild in under an hour.
Rob
#8 Shiney005
  • 9,554 posts
  • Car:Toyota Mirai
Posted 15 February 2025 - 09:56 AM
For 45 bucks, this probably could also save your car if a fuel line burst under the bonnet. Aeroflo and Bosch units are around $200.
  Attached File  Screenshot 2025-02-15 075415.png   795.73K   6 downloads
#9 hawk
hawk
  • 2,179 posts
  • Name:steve
  • Car:UC Torana
Posted 15 February 2025 - 11:10 AM
I'll try sus one out later today.
#10 rexy
rexy
  • 3,730 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 15 February 2025 - 03:56 PM
What fuel pump are you using?
#11 rodomo
  • 18,036 posts
Posted 15 February 2025 - 08:33 PM
Or the float level is too high?
#12 hawk
hawk
  • 2,179 posts
  • Name:steve
  • Car:UC Torana
Posted 16 February 2025 - 05:28 AM
I just checked the pump, its a proflow 6 to 8 psi pump.
Looked for fuel regs yesterday and could only find ones to suit EFI
#13 hawk
hawk
  • 2,179 posts
  • Name:steve
  • Car:UC Torana
Posted 18 February 2025 - 06:24 PM
Replacing the carb with a changeover rebuilt one. Just need to decide whether or not to go 600 again.
#14 Shiney005
  • 9,554 posts
  • Car:Toyota Mirai
Posted 19 February 2025 - 11:12 AM
Rochester or Edelbrock (if they still make 'em).
#15 UCSLE
UCSLE
  • 708 posts
  • Name:troy
  • Car:Goggomobil
Posted 19 February 2025 - 07:19 PM
Depends on what manifold you have .  The 600 will be ok on a small dual plane  , if it is single plane go for a 650dp
I have a brawler 650 dp and single plane on my 308 now but before i got the brawler it had a 600 vac holley and was never that good
#16 hawk
hawk
  • 2,179 posts
  • Name:steve
  • Car:UC Torana
Posted 20 February 2025 - 10:59 AM
Thanks guys, just got another 600 for now.
Still need to set float levels.
I have a torque power dual plane at the moment.
#17 hawk
hawk
  • 2,179 posts
  • Name:steve
  • Car:UC Torana
Posted 26 February 2025 - 09:34 PM
Still running pretty poorly with the new carb. it will idle fine and rev fine while stationary but when driving, anything much over idle it's got no go at all.
I'll remove the pressure regulator and see if that helps. as it's the only other change beside the rebuilt carby.
#18 LXCHEV
LXCHEV
  • 3,591 posts
  • Car:'76 LX - 383 Chev
Posted 26 February 2025 - 09:37 PM
Should you choose to enlist professional help at any stage Steve - go and see Eric down at Goody's Garage. He won't rip you off, and he's a guru with these sorts of cars. Loves his carb'd V8's.
#19 hawk
hawk
  • 2,179 posts
  • Name:steve
  • Car:UC Torana
Posted 26 February 2025 - 09:48 PM
Thanks Brett, they're a 2 minute walk from my work. I'll go see them for a chat on my lunch break tomorrow.
#20 Shiney005
  • 9,554 posts
  • Car:Toyota Mirai
Posted 14 March 2025 - 10:41 AM
Get it sorted Steve?
#21 hawk
hawk
  • 2,179 posts
  • Name:steve
  • Car:UC Torana
Posted 14 March 2025 - 01:21 PM
Yeah all sorted. the new carb had something wrong with it. exchanged it for another unit and the car is running well now.
