186-202 brine brass oil pump drive gear
1 reply to this topic
#1 biga064
biga064
  • 196 posts
  • Name:Adam
  • Car:EH Holden
Posted 30 March 2025 - 05:46 PM
Hello what’s the thoughts on bronze brass oil pump gear used for a roller cam set ups ? Are factory drive gear ok to use ? Thanks
#2 N/A-PWR
  • 9,637 posts
Posted 30 March 2025 - 09:30 PM
Hi there Adam,
 Tighe Cams,
 said to use the supplied brass gear with the Roller Cam.
Being the same size as the pump gear,
 I think it is only for the distributor.
I also imagine, the pump would need the hardened gear for the work it does.
Hope that helps. :3gears:
Edited by N/A-PWR, 30 March 2025 - 09:34 PM.
