Lowering top arm on LJ
#51
_gtr161s_
Posted 21 April 2007 - 04:53 PM
1" (one) would be dangerously unsafe as there isnt enough meat left to safely support the bolts and arm.
#52
_73LJWhiteSL_
Posted 22 April 2007 - 02:04 PM
Steve
#53
_73LJWhiteSL_
Posted 29 April 2007 - 12:18 AM
The correct distance is 5/8" according to limos measurements.
Steve
#54
Posted 29 April 2007 - 07:46 AM
#55
Posted 29 April 2007 - 04:35 PM
don't quote me yetThe correct distance is 5/8" according to limos measurements.
Steve
not easy measuring upside down while still in car,
got the GTR one out, Xu1 next weekend if time then I will remove bolts measure both from top down and subtract
#56
_73LJWhiteSL_
Posted 29 April 2007 - 10:26 PM
Steve
#57
Posted 06 May 2007 - 05:08 PM
there are two sets of holes in it for upper mounts,
one standard, one lower down and the $64 question, how far down
5/8" looks to be the go
there is very little metal in front of front hole, less than 5mm
#58
Posted 06 May 2007 - 05:34 PM
Edited by rorym, 06 May 2007 - 05:36 PM.
#59
_ber914_
Posted 17 May 2007 - 07:05 PM
Robert
#60
Posted 20 May 2007 - 02:51 PM
#61
Posted 31 May 2007 - 11:30 PM
i think when you get a wheel algnment they will work that out, as you should get one after the mod i would think.If you do lower the control arms does it require more or less shims?
#62
Posted 02 June 2007 - 02:56 PM
Took me about a day to get it close.PITA of a job with the v8 in there.
#63
_monaroman68_
Posted 25 June 2007 - 12:21 PM
#64
_big_als_army_
Posted 30 June 2007 - 12:28 AM
#65
_73LJWhiteSL_
Posted 30 June 2007 - 10:18 AM
Steve
#66
_big_als_army_
Posted 30 June 2007 - 01:57 PM
#67
_jklumpp_
Posted 03 July 2007 - 02:55 PM
Wheel alignment was no drama to get the desired settings, and car drives & handles beautifully on the road & track.....
I do agree however that all information that has come to light seems to suggest that 5/8" is the correct XU-1 measurement.....just a shame more people weren't forthcoming with that info when i did the mod....
#68
_big_als_army_
Posted 03 July 2007 - 05:00 PM
#69
Posted 22 June 2021 - 11:13 AM
Hi
Hope this helps
Bazza
Hi Bazza,
Yes this post is from some time ago... though I was wondering if by some slim chance you might be able to send me that photo that you have posted of this mod? I'm searching the forum but this post looks to be most relevant to this mod..
Thanks' heaps mate.
#70
Posted 23 June 2021 - 02:28 PM
Hi Bazza,
Thanks' heaps mate.
Now sorted.
#71
Posted 23 June 2021 - 08:24 PM
http://www.gmh-toran...ole-easy-tiger/
Edited by 73SUNBURSTEXYOUWON, 23 June 2021 - 08:25 PM.
#72
Posted 23 June 2021 - 11:23 PM
Posted: Sat Apr 03, 2004 10:31 am Post subject:
________________________________________
Electra Blue
The suspension on the XU1 differs in that the mounting for the upper control arm is lowered on the crossmember. I don’t have the actual measurement but you are probably correct in calling it an inch.
There are two sets of bolt holes which indicate that the lower one was drilled somewhere along the production line.
The 1970 service bulletin notes as important the the upper control arm is always reinstalled in the lower mounting position.
I would confidently assume that it was for handling purposes.
From what I have read this mod can be carried out on any LC/LJ Torana
but I would check on that before you pull out the old Black and Decker and start drilling a few holes.
This was disccussed sometime ago on this BB with some pretty good and informantive information. Perhaps someone with Search capabilities could locate it and post a link.
Posted: Sun Apr 04, 2004 5:41 pm Post subject:
mounting the upper wishbone 1” lower will also give it a higher roll
center thus giving the car less body roll in the front.
and this i would say is the reasoning behined the revised mounting
position
