also try ebay or second hand book shops.
any book from late 60's modles thru to early 80's will guide you on the motor, of course the rest of the car will reside in the specific torana manuals avliable.
aside that set the timing to around 6 deg and wip the cap off and check the mechanical and vaccum advance are working.
from there set the idle on the carby and the mixture screws to around the highest idle.
if both were way out you may have to reset the idle.
further to this you may have to compression test to confirm a sound motor to start with or you may never get it tuned right.
there is about fifty other little things i could cover but really the book is a good source to start with.
EDIT; leads, plugs, filters etc etc.
Edited by ALX76, 28 September 2006 - 04:59 PM.
