MHDT L34 Bond/Harvey 76 Car
1760 replies to this topic
#751 _TJ253_
_TJ253_
Posted 21 May 2007 - 06:09 PM
Nice work Nos looks hot 1 down 1 to go eh least u got to Pracitice On Rorys first
#752 _NRV051_
_NRV051_
Posted 22 May 2007 - 05:38 AM
starting to look like a race car, good work to both of you for your top efforts.
Gav
#753 _rorym_
Posted 22 May 2007 - 05:48 PM
I am in Rockhampton looking after our branch up here until Friday so I will be on and off when I can.
#754 _MRNOS_
_MRNOS_
Posted 22 May 2007 - 05:51 PM
You're always on and off Rory :tease:
#755 _ultrabluea9x_
_ultrabluea9x_
Posted 22 May 2007 - 05:53 PM
looks shit hot cant wait to see the pair finished together :clap: :clap:
#756 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 22 May 2007 - 05:55 PM
Coming along very nice.
Wish i could say the same. :<_<:
#757 _rorym_
Posted 23 May 2007 - 08:59 AM
Hardy being in Rockhampton..Just been to see Ray at Dobinsons Springs and order my springs for the L34. We played with lots of numbers but he explained that the bedford springs are 1mm thicker and 1 coil less so they will sit 20mm higher than the Low A9X fronts. Perfect!! 1165 lbs front 285 lbs rear.
Edited by rorym, 23 May 2007 - 09:01 AM.
#758 _LXChev366_
_LXChev366_
Posted 23 May 2007 - 09:36 AM
Hey Rory, the spring poundage ^^^, is that the given poundage for a torana for circuit racing, as I want to change the setup in mine and my fronts are about 900 lb. My car definetly needs better cornering speed as it suffers in this department... EC on the weekend proved that, I have the outright speed but not corner speed. My car also has a slight forward rake. How much $ were these springs by the way.
Edited by LXChev366, 23 May 2007 - 09:38 AM.
#759 _rorym_
Posted 23 May 2007 - 09:39 AM
Its the poundage for the spring..car is irrelevant...Thats what Sam 350LH uses and says they are definately the go. $174 for the fronts..If you ring and order them..tell them there is an order in for me Rory McDonald Master Builders and they will add them in and make them at the same time.
#760 dattoman
  • 16,487 posts
Posted 23 May 2007 - 09:44 AM
1165.... geezus
285 rear ?.... no full drop tank ?
#761 _rorym_
Posted 23 May 2007 - 09:57 AM
That was Harrys spec on the race car.
#762 _rorym_
Posted 23 May 2007 - 07:27 PM
I can see why Bomber Watson had a play in Rocky...just to create some excitement!! Pretty quiet here!
#763 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 23 May 2007 - 10:43 PM
..but things livened up when they got their first set of traffic lights.
#764 _rorym_
Posted 24 May 2007 - 06:02 PM
Home at last...Got the hydro clutch stuff...Datto is sending the slave and I then need to make the bracket. Haven't heard from NOS but I have been away all week. Day off tomorrow for the show.
#765 _rorym_
Posted 25 May 2007 - 08:26 PM
NOS is in the shed high on clear coat.
#766 _TJ253_
_TJ253_
Posted 25 May 2007 - 11:03 PM
So does that mean he will have ure car done this weekend?
#767 _rorym_
Posted 25 May 2007 - 11:04 PM
Never push a man that demands perfection..when I know...you will know.
#768 _rorym_
Posted 27 May 2007 - 11:46 AM
NOS has had sinus all week, I have gone out with a head cold in sympathy for him! Sniff!... He is hoping to get some clear on today in Bris..its pissing down up here.
#769 _rorym_
Posted 28 May 2007 - 05:29 PM
NOS has got some clear on! NOS has got some clear on!
#770 _rorym_
Posted 28 May 2007 - 06:33 PM
#771 _rorym_
Posted 28 May 2007 - 06:48 PM
#772 dattoman
  • 16,487 posts
boot dent ?
#773 _rorym_
Posted 28 May 2007 - 07:07 PM
Under spoiler...didnt worry about it.
#774 _rorym_
Posted 28 May 2007 - 08:20 PM
I felt for the boy this morning...he had a hiccup that needed a redo on some painted areas..but seems to have got it done..What a trooper!!! :clap:
#775 _MRNOS_
_MRNOS_
Posted 28 May 2007 - 08:41 PM
Needs to be buffed still, and thats about 2litres of clear only, still at least 2litres to go, bit of bloody dirt got under the clear had to be on the white part too :cry:
