MHDT L34 Bond/Harvey 76 Car
1760 replies to this topic
#1326 _rorym_
Posted 03 April 2008 - 06:28 PM
The deal is to get the thing in place and all the other bits welded on so I can move forward...anything suspect will be upgraded. Gotta say...I love the floor...
Edited by rorym, 03 April 2008 - 06:40 PM.
#1327 _82911_
_82911_
Posted 03 April 2008 - 08:47 PM
Trust me Rory..... brace the chassis mount end of the panhard rod.....
As Rodomo quite rightly said they tear out of Commodores standard.
Brace it to the opposite chassis rail ideally.....
#1328 _rorym_
Posted 03 April 2008 - 09:07 PM
Thats pretty easily done. How's the height and line Greg?..Tried to decify your explanation when fitting it. Its parralel when on the ground, i.e. the bolt up points are in line..
Edited by rorym, 03 April 2008 - 09:09 PM.
#1329 _Bomber Watson_
Posted 03 April 2008 - 09:25 PM
You made a good call getting that bloke to do it instead of me powering down R.
He did a better job than i coulda. But had i the time (and if i hadnt gotten the a new second job working weekends) i woulda tried.....
Looking great.
#1330 _82911_
_82911_
Posted 03 April 2008 - 10:15 PM
it looks about right.. just brace it or it will fall off first chance it gets.
#1331 rodomo
  • 18,039 posts
Posted 03 April 2008 - 11:31 PM
Can't argue with that :spoton:
#1332 Racehatch
Racehatch
  • 1,027 posts
Posted 03 April 2008 - 11:35 PM
Looking good mate, just curious, the upper arms, they arnt poly at both ends are they?
#1333 _Chriskoss-79uc_
_Chriskoss-79uc_
Posted 04 April 2008 - 12:08 AM
looking very good i love this car :)
one question rorym how did u attach your foot petals as i have a set similar but not to sure how to put them on did u just drill into the metal plate and use the screws?
Cheers Ben
I went though the same problem...
It's pretty hard to drill though the metal pedal plates when their installed, try taking them off, putting them in a vice carefully and drilling through..
Otherwise you could just remove the pads on it from stock and somehow glue/bond the new pedal pads on?
#1334 _rorym_
Posted 04 April 2008 - 06:50 AM
Funny you mention that Sam...I installed rubbers into the spare set I have as the young bloke was welding away...After talking to M@ I am fitting the rubber uppers on the weekend in place of the Nolathene.
#1335 MRLXSS
  • 12,414 posts
Posted 04 April 2008 - 08:12 AM
Looking Great mate! Keep up the good work!
#1336 _rorym_
Posted 04 April 2008 - 04:04 PM
OK...Done a bit of research...we will use 12mm plate cut to triangulate down each side of the chassis rail...and I am running 50mm channel off the arm right across under the boot to the chassis on the other side as per Gregs suggestion..If it falls off then I just fit the Floord hat and a Watts Link! :huh:
#1337 _rorym_
Posted 04 April 2008 - 05:43 PM
Talking to the welder today we are going with a 12mm plate triangle welded to the inside of the chassis rail about 150mm x 150mm welded to the tank side of the arm and chassis to add the strength we need. By the way...for 2.5 hours he charged me $100...love small country towns! :clap:
#1338 TerrA LX
Posted 04 April 2008 - 07:37 PM
I might start advertising my skills
#1339 _82911_
_82911_
Posted 05 April 2008 - 07:08 AM
Your using what? 1/2" plate. :blink:
Man, I usually use 25x25x 1.6 SHS and that is plenty.If you are going to use 1/2 plate then for god sake cut some holes in it. This is a race car right? It hasn't morphed into earthmoving equipment or something has it..... :spit:
Edited by 82911, 05 April 2008 - 07:10 AM.
#1340 _82911_
_82911_
Posted 05 April 2008 - 07:23 AM
All shit stirring aside......
Mate this is what you want to end up with. You always get strength through design in a race car, not by using large cross section material.
#1341 _rorym_
Posted 05 April 2008 - 07:26 AM
Hahaha! Yeah Yeah...
I found an article on a MG being built for racing in UK...the panhard setup is exactly what you have drawn and what I was saying 2 posts back...I think I will run with that...not the welders suggestion on reflection.
Edited by rorym, 05 April 2008 - 07:30 AM.
#1342 _82911_
_82911_
Posted 05 April 2008 - 07:33 AM
looking at the above pic.....
a couple of suggestions.
Don't use differnt profile materials next to each other it looks amateurish.
And GAL has no place in a race car. It is right up there with making things out of star pickets!
#1343 _rorym_
Posted 05 April 2008 - 08:11 AM
Yeah was thinking same size section square tube as the arm as the brace.
#1344 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 05 April 2008 - 11:22 AM
looks like he used an old bedframe.
Rory, Dave has just done his here in Perth.
I think a quick look on his thread might show a pic or two.
Welby
#1345 _rorym_
Posted 05 April 2008 - 12:05 PM
Dave??
#1346 _rorym_
Posted 06 April 2008 - 09:25 PM
355LX I am guessing...
I have this week off (school hols) so will try to get it all but finished.Decide in for a penny..in for a pound..ordered the Harrop arms....Bugger! :furious:
Edited by rorym, 06 April 2008 - 09:26 PM.
#1347 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 06 April 2008 - 09:43 PM
That's interesting.
I actually answered you with a paragraph on Daves work.
Welby
#1348 _rorym_
Posted 06 April 2008 - 09:45 PM
Sheet@!...How far back?..If it was b4 today it was deleted in my brain...???
#1349 _rorym_
Posted 07 April 2008 - 06:29 PM
Missus bought a new truck to transport the race car today...she says it is for the driving school...RIGHT!!..2002 Nissan Turbo diesel...will banana the back and fit a bull bar.
#1350 _Bomber Watson_
Posted 07 April 2008 - 06:35 PM
I've said it before and i'll say it again.
I want a missus like that.
