MHDT L34 Bond/Harvey 76 Car
1760 replies to this topic
#1401 _rorym_
Posted 15 May 2008 - 05:49 PM
Hope this video works..
Got fuel pissing out the top of the new pressure regulator unit...no idea on that one.
Fired first go..
65/70 psi straight away at idle...wound it over for a bit first to pump it up.
That cam is FARKING HUGE!!!
No other problems..
Like Laz..I have a WOODY!!..and my wife has a wide on!!..go figger?? :huh:
#1402 _MRNOS_
_MRNOS_
Posted 15 May 2008 - 05:50 PM
Bloody hell fix your idle!!!
#1403 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 15 May 2008 - 05:54 PM
sounds like its time for you and the wife to get out the Twister mat :tease:
Edited by makka, 15 May 2008 - 05:55 PM.
#1404 _rorym_
Posted 15 May 2008 - 05:56 PM
Was running a bit slow..
#1405 _Skapinad_
_Skapinad_
Posted 15 May 2008 - 06:04 PM
mmmmmmmm sounds nice....
#1406 _rorym_
Posted 15 May 2008 - 06:13 PM
nude one Makka...
#1407 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 15 May 2008 - 06:17 PM
nude one Makka...
is there any other kind?
:spoton:
#1408 GML-31
Posted 15 May 2008 - 06:34 PM
why??? its running at his speed hey Rory.... exciting day mate.
#1409 _rorym_
Posted 15 May 2008 - 06:45 PM
Psst...was actually the second run...I tried to stop the reg from leaking and reduced the pressure..It sounded horn on the first one. :spoton:
#1410 racean69
racean69
  • 782 posts
  • Name:Rod
  • Car:LH sedan
Posted 15 May 2008 - 07:24 PM
excellant...yahooooo
#1411 _rorym_
Posted 15 May 2008 - 08:20 PM
^^ Times 2!!! :spoton:
#1412 _rorym_
Posted 15 May 2008 - 11:25 PM
The new 15 x 10 rears
and just because my wife wanted to show how fanatical I am...this is the inside of the rim.
#1413 _rorym_
Posted 17 May 2008 - 03:46 PM
Pulled the regulator apart for a look...it has a brass circular pressure ball sitting in the middle of the diaphram...It appears the fuel is just going around the diaphram...weird system...
2 other probs...electric fan isnt kicking in but if we direct wire it it is OK..so the relay/temp sender seems to be faulty...
and a brand new thermostat was faulty..wouldnt open to flow the water so I took it out and all was flowing OK..
Hiccups...hiccups...but all minor thank God..
Sheet it sound tough though!
#1414 _MRNOS_
_MRNOS_
Posted 17 May 2008 - 03:57 PM
Well more video then????!!!!!
#1415 _rorym_
Posted 17 May 2008 - 03:58 PM
Will let it cool down first..
#1416 _Bomber Watson_
Posted 17 May 2008 - 04:14 PM
R, thats how most bypass regulators work. The diaphragm should open up to allow excess fuel pressure back into the return line, but as far as direct flow though it theres nothing to stop it. Thats why there so good!!!!
Sounds like your getting her sorted nice and fast!
#1417 _rorym_
Posted 17 May 2008 - 04:30 PM
Think the fuel is passing between the edge of the diaphram and the brass centre piece..allowing it to come up to the top above the diaphram...dont think it is supposed to do that..
#1418 _Bomber Watson_
Posted 17 May 2008 - 04:31 PM
It sholudent be able to?
Should be sandwiched between two pieces of the brass centre piece...
Im just going by my Aeropro one though, Holley is known to be strange.
#1419 _rorym_
Posted 17 May 2008 - 04:33 PM
If you tug at it slighty you can see the edge of the diaphram..think it should be pinched between the top and bottom of the brass centre piece..not so..
#1420 _Bomber Watson_
Posted 17 May 2008 - 04:36 PM
If you cant get it to squeeze better perhaps you could get a bit of RTV silicone and wipe around it, then let it dry.
Dodge i know but would be ok just to test if this is the problem or not.
#1421 _rorym_
Posted 17 May 2008 - 04:37 PM
Thats my next try..
and just for NOS...More video...
#1422 GML-31
Posted 17 May 2008 - 04:52 PM
whats with the garden hose breather pipes... me thinks there are 2 bongs up that way missing their hose....
#1423 _rorym_
Posted 17 May 2008 - 05:08 PM
Trying to find clear reinforced 18mm ID hose...none around...only in green..will get some to replace..need a low K& N kit about 2" high and dump the 3" filter..then I can get the 1" spacer back in under the carb.
Edited by rorym, 17 May 2008 - 05:13 PM.
#1424 Racehatch
Racehatch
  • 1,027 posts
Posted 17 May 2008 - 06:09 PM
Sounds good Rory, what exhust system did you end up going for?
#1425 _rorym_
Posted 17 May 2008 - 06:43 PM
Lol...straight extractors Sam..thats to be done next week.
