Banjo diff damper???
18 replies to this topic
#1 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 07 October 2006 - 07:33 PM
Hi guys and gals.
Bought myself a spare complete banjo diff setup. It has, what I am told, a factory vibration damper. Just wanted to know if this is for real and if anyone has ever come across one.. Check out the photobucket link for a picture.
https://cache.gmh-to...ry/P1010067.jpg
I have heard about them before but never seen one..
Thanks..
Edited by Redslur, 07 October 2006 - 07:39 PM.
#2 _CHOPPER_
_CHOPPER_
Posted 07 October 2006 - 07:45 PM
First I've heard of them.
#3 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 07 October 2006 - 07:59 PM
yep i had one on 1 of my hatches years ago and i mean like 15 years or so ago,
weird looking thing and wondered WFT is that and was told the same thing
#4 Heath
  • 18,403 posts
Posted 07 October 2006 - 08:06 PM
Very, does it bolt onto anything else?
#5 Toranavista
Toranavista
    'Let There Be Rock' 1977
  • 2,862 posts
Posted 07 October 2006 - 08:28 PM
Mmm saw one for the first time ever only the other day. Wonder if there is a part #? I wonder how they work? I wonder what there worth? Looks rare.
#6 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 07 October 2006 - 08:35 PM
In all honesty, I can't imagine how it works and I am a mechanic!!! It only bolts on by two of the housing bolts. No other attachment to the diff at all. It is almost like it is a harmonic damper or something similar.
#7 gtrboyy
gtrboyy
  • 3,241 posts
Posted 07 October 2006 - 10:28 PM
Never seen one of those before,I can't see how it would work or make a difference.
#8 _DocDamage_
_DocDamage_
Posted 07 October 2006 - 10:54 PM
It's meant to damp torque vibration. Your tailshaft meets the diff at an angle and despite the uni, the front of the diff is forced slightly up and down causing virtually undetectable low frequency vibration. You can see by the flat mount & arm that this is the direction it effects. It was suggested to possibly provide some degree of car sickness relief.
#9 LS1LX
LS1LX
  • 1,931 posts
Posted 08 October 2006 - 02:02 PM
It6 doesnt make the diff any stronger, its still just a puny banjo.
#10 Toranavista
Toranavista
  • 2,862 posts
Posted 08 October 2006 - 09:12 PM
Any more thoughts on original or aftermarket?
#11 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 09 October 2006 - 09:26 AM
its factory however on the diif that mine was on it was a sunbird, since then i've never owned a sunbird and never seen one again...so it could have just come out on the sunbirds
#12 Dangerous
Dangerous
  • 948 posts
Posted 09 October 2006 - 11:21 AM
It's a factory part, but only on 4 cylinder Toranas as far as I know - maybe only on the 3.9:1 diff ratio??? It's been a while since I've seen one, but the one in the pic looks larger than the few I've seen. The LX parts manual has them listed, with a drawing of them.
#13 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 09 October 2006 - 12:41 PM
Just out of interest, the diff came out of a LX SS hatch 4.2. The ratio is 3.08. Impossible to say whether or not it was fitted as standard or taken from off another car. The fellow who owned it previously advised me it was fitted as standard..Who knows??
#14 Dangerous
Dangerous
  • 948 posts
Posted 09 October 2006 - 10:37 PM
Straight out of the parts manual - "Rear axle damper - Sunbird hatchback. Damper, pn 92001730,
spacer pn 92001731
bolt pn 120647,
washer pn 10321.
Looks like it was used in 4 cylinder hatchbacks only. The diagram in the manual looks a lot like the pic you've posted, so it's most probably an oem one.
#15 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 10 October 2006 - 12:05 PM
Thanks Dangerous, sounds good to me.. I should have checked my manual first :D I certainly will be having a look when I get home.. It all seems right becuase of all the SL/R's and SS's I have had something to do with, not one of them have ever had it fitted..
#16 _Yella SLuR_
_Yella SLuR_
Posted 10 October 2006 - 01:30 PM
OMG, does it have chrystals?
#17 _CHOPPER_
_CHOPPER_
Posted 10 October 2006 - 06:03 PM
You thinking along the lines of the Energy Polariser?
#18 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 11 October 2006 - 12:15 AM
I thought exactly the same thing when I firs read this thread :tease:
#19 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 11 October 2006 - 08:00 AM
not the polverizer..... :rolleyes:
